need help on bizhub C250
  • goldencup
    • Nov 2008
    • 366
    Hi, i have a bizhub C250, actually the machine has no problem. My only concern is that the client wants the machine to have an account track so i did input the password they needed. I just noticed that every time i log in, the display screen is always default to scan and i still have to press the copy button so that it can be used as copier and not as scanner. Is there an adjustment on the machine so that when i log in the display is default to copy? Thank you very much.
  • ni311
    • May 2008
    • 658
    Re: need help on bizhub C250
    Search in User or Machine Settings, there is an option that is called 'Factory Default' and/or 'Current Settings'. I guess this will do the trick for you. You might read the User Manual, if you have enough patience, I'm sure you'll find there what you need.
    Konica Minolta Error Codes - Explanations and Solutions
    • KM7155
      • Aug 2008
      • 146
      Go to copy screen, then press the utility/counter, user setting, initial setting and select current setting
      • montana
        • Aug 2008
        • 392
        hi...in the utility mode select the initial mode..in the default settings choose copy as a default when the machine start up...i hope it is help...
