Konica Minolta C250
  • Avskrap
    replied
    Re: Konica Minolta C250
    Originally posted by Shadow
    as I stated above, the developer needs to be replaced.
    the 2557 error is an issue with the developer now.
    you have spent so much time pissing around with toner and a new drum that you are throwing money down the drain.
    the developer needs to be replaced and the F8 process needs to be run.
    get the service manual and read through it.
    these machines are notorious for this kind of issue.
    I spent may years servicing these machines and had all of my new techs cut their teeth on them.
    replace the developer and quit throwing good money after bad.
    Well, he says it's a C250. No separate developer, simply an imaging unit.
  • Shadow
    replied
  • nmilisic
    replied
    Originally posted by minimerlin
    I will have to leave that up to you! It is simply a case of LOOKING to see if the drum turns! Are you a tech at all? I suggest you call one if you need to be advised how to tell if a component is turning! I will now withdraw from this post as I cannot look for you..sorry.
    I'm tech for Ricoh b/w machines. This KM c250 is in local school, and I was tried to help them.
    New K IU and new toner and c2557 still there...
    Any ideas?
  • minimerlin
    replied
    Originally posted by nmilisic
    No I'm not sure that K IU is turning, please advise me how to check?
    Thanks.
  • nmilisic
    replied
    Have you made sure that the K Image Unit is actually turning?
    Thanks.
  • minimerlin
    replied
    Today I tried new black IU, machine show c2557 again.. Also, machine show message that I need new black toner but when I check that toner cartridge on another c250 - everything work perfect?
  • nmilisic
    replied
  • skazic
    replied
    C2557: Abnormally low toner density detected Black TCR Sensor..........
    This service manual says, but is probably missing the black toner Replace the toner,
    go into service mode and turn the toner dispensing
  • Shadow
    replied
    where did you read this information?
    the manual says to open and close the front door.
    you need to replace the developer in this machine.
    if you are an authorized service tech, you will have the correct code to access the service mode.
  • nmilisic
    started a topic [Error Code] Konica Minolta C250
    Konica Minolta C250
    Error code: c2557..
    I read that I should reset this code in tech rep mode, but when I go with: stop 00 stop 01, than "00000000" and after that "end" - but there is no "end" on display?
    Please, help If anyone know how to enter tech rep mode.
