Konica Minolta C20 Error Code 13F0
  • atiq
    • Jun 2010
    • 25
    [Error Code] Konica Minolta C20 Error Code 13F0
    There are three types of people in this world: those who make things happen, those who watch things happen and those who wonder what happened.
  • Gaffers01
    • May 2011
    • 335
    Re: Konica Minolta C20 Error Code 13F0
    That error code is likely something more serious to do with the main boards if I remember rightly,
    check no cables have come loose.
    • Hansoon
      • Sep 2007
      • 3384
      From the book:
      13F0: Engine control failure
      Relevant electrical parts
      Print control board (PRCB) MFP board/1 (MFPB/1)
      1-Check the cable and connector for proper connection and correct as necessary.
      2 Change PRCB.
      3 Change MFPB/1.
      Hans
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • remati
          • 149
          Normaly is a "flat cable" that connect the boards "PRCB andMFP"... is a small one
          ...but check all the connections and all the flat cables on the boards
          Best regards
          • MFPTech
            • 486
            Best regards
            Has this been resolved please?
            Toda i had a brand new machine out of the box with this error. The machine initializes the scanner and fuser, stays in warming up phase for a while and instead of going to Ready it throws the error. The fuser is hot.
            The service manual says it's an engine error and recommends rebooting the main unit. Tried to write firmware but the moment I turn the machine to bootrom mode the error led is on.
            Thanks in advance!
