Ineo +200 Scanning to SMB ok but auto resending file to Unregistered Account
  • Pinoy_Tech
    • Feb 2010
    • 47
    http://i49.tinypic.com/kda5up.jpg
    Thanks to all,
    576P_Tech
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    Re: Ineo +200 Scanning to SMB ok but auto resending file to Unregistered Account
    What is the IP of the computer you're sending to?
    Parts: Its what your copier craves!
    • Pinoy_Tech
      • Feb 2010
      • 47
      After about 3months of my query here, I been able to comeback to the same customer and analyzed the problem regarding this re-sending scan issue. I noticed that the IP add is the same pc where I am sending the files but the files are really receiving to the correct destination folder. For about an hour or two, I checked all default settings and other possible wrong settings then I decided to delete & re-setup again the scanning account but the same scenario is happening. Last and final resort, I went to reset program mode via micro switch at the back and reset all possible memories that displayed on the panel. Guess what, problem solve at last !!!
      • emujo
        • Jun 2009
        • 3009
        These MFPs have the ability to capture scanned images and transfer that data to an FTP or shared folder..I have only seen one customer use this and they were fanatics about who scanned what...This has nothing to do with setting up FTP or SMB scanning, and would not be an address listed in the address TAB, but if the mode is turned on, and the data could not make it to the "capture" server, I belive the MFP will send a msg showing a scan failure...Your total reset probably cleared this ADMIN setting. Emujo
