Konica 7155 Drivers for Windows 7
  • Doug James
    • Jan 2012
    • 935
    Does anyone know where I can get the drivers for this machine in Windows 7 format ?
  • Brischaffer
    • Oct 2008
    • 68
    Re: Konica 7155 Drivers for Windows 7
    I just checked on the KMBS tech site and they do not have them for that machine. The highest OS was XP 64-bit. Time for an upgrade!!!
    • Doug James
      • Jan 2012
      • 935
      Thanks so much...
      • Brischaffer
        • Oct 2008
        • 68
        Any time!
        • mrwho
          Major Asshole!
          • 4299
          Your best bet is to use an HP PCL driver - try several Laserjet models until you find one that does duplex and allows you to choose the paper trays. At worst I believe you'll be able to print single-sided, but maybe you get lucky. Forget about user codes and finishing options, though...
          Mascan42
          Ibid
          • TheOwl
            • Nov 2008
            • 1732
            If the print controller has the optional Postscript kit in it, then you are in luck because there is a Windows driver available.
            1. Add Printer
            2. Select the port to print to or create a new one
            3. Windows Update
            4. Konica
            Sometimes the Windows Update can take a while to download the list of printers so be patient.
