toner related problem
  • stedros
    • Oct 2011
    • 34
    [Misc] toner related problem
    i hv a bizhub 20 machine but at our market i have tried to look 4 its toner da TNP24 AND I HV FAIL plz anyone who knows da toner which can work in it,i donot mind even if its refill because am stucker thanks GUYS
  • jimmyjwc
    • Jun 2011
    • 7
    Re: toner related problem
    Hi
    Try using Brother TN620 or the high capacity TN650 cartridges. The drum unit is DR620.
    • stedros
      • Oct 2011
      • 34
      i have never seen a TONER CATRIDGE OR a machine 4 BROTHER on our market EVEN i had that i dea already but failed to get even an empty catridge
      • jimmyjwc
        • Jun 2011
        • 7
        Check out this link Brother and compare the B20 specs to this m\c. I got the toner and drum wrong. Check the consumables on the page for the right toner and drum.
        • Hansoon
          • Sep 2007
          • 3401
          The Bizhub C-20 is a totally different machine than the Brother MFC-8880DN......
          Hans
          • stedros
            • Oct 2011
            • 34
            Hans
            thnks i will try it out.
            • johanve
              Sorry Guys
              I know this is not the correct thread for your problem, but I wanted to know if anyone has experienced the same or similar problem. On the b20 when you fax a big document or scan it to pc(control centre via usb) the machine hangs and then restarts. Nobody that I talked to has ever had this problem.
              Please Help
