I want to remove the tray 1 to c6500
  • tasosquesta
    • Jan 2012
    • 11
    I want to remove the tray 1 to c6500. disconnect it from the contact but now unable to get photocopy. What should I do to operate the machine normally without the tray 1?
  • dljorg
    • Sep 2009
    • 93
    Re: I want to remove the tray 1 to c6500
    I assume it does not work?
    You might try trading the entire feed assembly with one of the other trays.
    Setting DIP Sw 18-0 to 1 will make Tray one disabled.
    • tasosquesta
      • Jan 2012
      • 11
      Thank you very much. Where is the Setting DIP Sw 18-0 to 1
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • TheOwl
          • Nov 2008
          • 1732
          By this comment, I would assume that you aren't a trained tech. If you aren't, then please get some one in and don't play around with DIPSW settings as you could end up changing the wrong setting which in turn means an even bigger bill for the time spent getting your machine back online.
