C203 making noise
  • bkamoga
    • Oct 2011
    • 31
    C203 making noise
    Hi all l have achallanging problem on biz hub C203 its making noise
    when its stablizing and after the stablizing the noise stops
    and when you do run papers in the testing mode u hear no noise
    when u are printing black only no noise, but when u are printing colour the u
    hear the noise almost between the timing and the exit assy
    i hve changed the fusing Drive , i have removed the hopper section
    i hve checked all the gears, all seem to be rotating fine ,
    pliz any one with the solution advice.l hve changed even the timing section , tranfer belt ,
  • Zeldaman
    • Mar 2011
    • 946
    • bkamoga
      • Oct 2011
      • 31
      Re: C203 making noise
      hi thanks but where is the tonner recyling drive located in the machine
      • minimerlin
        • 851
        You need a service manual if you do not know where the unit is. Try having a look at the rear of the image units!
        Please do not PM me without asking first.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Sounds like an interesting problem, havent seen this before.
          there is something else going on here which is to do with colour developing/drum drive or colour transfer roller extension/retraction.
          in black only mode the colour imaging unit drums and developer rollers do not rotate and the colour first transfer rollers are retracted (depending on acs config, im not sure if it even applies in service mode tests)
          if its ONLY happening in colour mode I'd be inspecting the colour imaging units, & main drive unit.
          You say youve replaced the fusing drive section & transfer belt, so that rules out the first transfer roller retraction mechanism.
          Please let us know what the solution was when you find it.
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
