C550 Jamming when stapling
+ More Options
Posts
  • Haroldbfix
    • 212
    As anybody seen this issue? It gives a 72-18 jam code when stapling. The machine has only 4K on it. The paper doesnt make it to the stacker entrance sensor in time. This machine is eating my lunch. HELP!!
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    I just looked up the code on Konica's website and this is what I found:
    [ID No.] TAUS0800688EN00
    Statistics
    [Last Used Date]
    [Score]
    Publisher
    [Company] BUS [Group] BUS_Service_Workgroup
    Contents
    [Original Doc. No.]
    [Open Date] 3/7/2008 [Doc. Language] English [Doc. Priority]
    [Product Name] bizhub C451
    bizhub C550
    bizhub C650
    [Option] FS-519 [Subject] FS-519, J72-18 error when copying and/or duplexing. [Description]
    [Solution]
    CAUSE: Separation Cover not removed.
    SOLUTION: Review page E-5 of the attached installation instructions for the punch kit and verify the correct cover has been removed. This will assure properly installation of the punch kit.
    Hopefully this will help you. If not, let me know.
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
    • Livebychance
      • Dec 2007
      • 34
      remove mylars as the paper travels down plate, four in total.
      607 has mylars (550,650 stapler finisher)
      606 does not (500)
      215 does not (8050)
      • Haroldbfix
        • 212
        Statistics
        [Last Used Date]
        [Score]
        Publisher
        Contents
        [Original Doc. No.]
        bizhub C550
        bizhub C650
        [Solution]
        Thanks for the tip, however its a FS-517 I should have mention that earlier.
        • Haroldbfix
          • 212
          606 does not (500)
          215 does not (8050)
          Are the mylars on the FS-517 also?
          • laserman06
            • Dec 2007
            • 323
            I am not sure, but I would think so. They are basically the same finisher, but one has a booklet folder. If you pull the finisher carriage out, look down from the top and you should see the mylars.
            Ps 46:10
            • Haroldbfix
              • 212
              OK the problem was resolved. It turn out to be a Driver issue. After spending some time on it. The jamming only appeared when printing. It would always jam on the last sheet feed to the stacker. If you removed the jam that same last sheet would continue to jam. The customer was using a PS Driver version 2.1.0.0.
              I updated it to 6.1.2.BT
