BH350 fax kit
  • KM7155
    • Aug 2008
    • 145
    [Misc] BH350 fax kit
    Hi Guys,
    some question regarding the FK50s for B350.
    what is the purpose of the battery and the memory?
    i try the fax without these 2 items, the fax is working.
    im lost why we need to buy the memory and battery which is not needed for the fax function.
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: BH350 fax kit
    the battery is for maintaining your programed numbers and settings should you have a power failure or the cleaners unplug the machine.
    the memory is for sending larger documents and memory sending during later hours of the day/night when long distance rates are lower.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • KM7155
      • Aug 2008
      • 145
      Re: BH350 fax kit
      i heard the battery is for Di3510 model only.
      i did try to unplug the power and leave the machine without power connected for 1 hour,
      after restart, my programed number still there.
      • ck1
        • 485
        Re: BH350 fax kit
        No bizhub if you but the fax kit come with the battery . but no battery also can work ( i buy used fax kit without battery ) memoey is for IP fax only
