Di3510 to Di3510f
  • Phill.Harden
    • Aug 2007
    • 27
    Di3510 to Di3510f
    Hi,
    I am wanting to move the fax parts form a high volume Di3510f to a low volume Di3510.
    I have connected the battery and fitted the scan board, the print controller, the fax board & the network card.
    The web interface reports the fax as not installed. I think I am missing something obvious but it has not put up its hand and waved for a couple of Hours... Would appreciate any help.
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: Di3510 to Di3510f
    Does the control panel on the low volume 3510 have a button on it to access the fax? That would be a deal killer.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2142
      i had these 2 machines side by side and never worked out how to convert the non f into an f.
      be interesting to know what exactly is the secret part that makes the magic happen.
      the non f's require cutting sheet metal too as there is no cutout for the line ports from memory.
      the f version does have a different control panel, as it has a pause key (for dialing)
      • mo0651
        • 1054
        the machines have different boards, di3510 not configured for fax.
        • Darren King
          copiertech
          • 652
          I have done this twice. You definitely have to swap MFBS boards and NVRam. I think I remember swapping main boards as well. And control panels a previously mentioned. No need to cut sheet metal either.
          Hope this helps.
          Darren
          • ck1
            • 485
            Just swap the control panel and fax kit only . You can di3510 to di3510f just this two parts to swap
            • Phill.Harden
              • Aug 2007
              • 27
              Thanks All,
              I Found with my machine I needed
              Battery
              Fax Board & connector
              I Could swap the sheet metal panel for line access
              Control Panel
              Now I just have to make it all beautiful....
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2142
                wow, thats good to know.
