Hello everybody, Good day...I am coming across many 7145 with the scanner boards and I have successfully installed a couple of machines with scan to box facility in the field.But in the same 7145 model some machine is not displaying the box function when pressing the scanner button. My belief is that all of 7145 are having scan to box function and there are some bit switches or something in the service mode to enable it.If anybody knows how to enable scan to box feature in 7145,please give me a help hand..Thanx....
konica 7145
thanks a lot for ur reply my friend..Even if there is no hard disk installed can we scan to PC(SMB)? I have tried scan to PC(SMB) with a stand alone pc by giving the name of the particular pc and making a shared folder in the hard drive.But when it comes to a pc under network its name is formed by a lot of alphabets (eg.david.digitalsolutions.local) and such a long no. of characters are not accepted by the machine. So can u please guide me how to scan to PC (SMB) of a client pc under a network..
Thanks a lot...Comment
Thanks a lot...
If it fails there will be an error code - NXX I think. There will be a scanner user manual that has a very brief explanation of the error codes.
Hope this helps,
GoodluckThe force will be with you always.Comment
