The CS6500 does not turn on.
  • mr.propper
    • Sep 2009
    • 16
    [Electrical] The CS6500 does not turn on.
    Hi all,
    The C6500 does not turn on.
    the display is black and the green power safe LED Status is on.
    This error is not in the Service manual described.
    i have
    replaced, without success:
    Image processing board (IPB)I/F board (IFB)Image memory control board (IMCB)Program of overall control board (OACB)
    Printer control board (PRCB)
    do you have another idea?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: The CS6500 does not turn on.
    After replacing oacb did you flash the firmware. A virgin board from KM does not come with firmware and needs to be loaded via iswtrns program. The machine "boots" straight to this mode and only needs you to run the upload from your pc via usb.
    • mr.propper
      • Sep 2009
      • 16
      Hi Mr.Spock,
      yes i have.
      After change oacb the power safe LED flashes red.
      I have install I1 - I5 of this with ISW-trans successful.
      • knightfall
        • Jul 2006
        • 633
        may want to look into this bulletin which description is a dead op panel caused by a short, bulletin 6085.
        good luck,
        Get your facts first, and then you can distort them as much as you please.
        • seniortech
          • Dec 2007
          • 180
          DC Power Supply 1/2
