reset and replacing fuser unit bizhub c550
  • vmp007
    • Sep 2025
    [Error Code] reset and replacing fuser unit bizhub c550
    I did replace the fuse, but my machine is still showing "have the fusing unit replaced soon" what do I do to clear this message... pls urgent help will be very helpful
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: reset and replacing fuser unit bizhub c550
    What fuse did you use?
    The gene pool could use a little chlorine.
    • swg4765
      Which fuse? Did you make sure you were using the properly rated fuse? There is no way to reset the message. It is reset by the fuse blowing.
      • emujo
        • Jun 2009
        • 3009
        1. replace the fuse again with the proper one, or put a new fuser in.
        2. if this does not work then you have a bad PRCB..you can check to make sure you have 24VDC going to the fuse to blow it.
        3. Install the PPLM mod...MFP will not stop cranking out copies just because some consumable item is past it's bedtime..Emujo
