Bizhub 200 Abort errors and missfeeds after drum&dev replacement
  • xeroid
    Document Technologies Pro
    • 148
    Replaced Drum & Developer, reset counters. Had extreme difficulty getting F8 ATDC setup to complete. Abort 0000e0422, 201, 004's and random other codes no doubt. Missfeeds Area O all three trays now. First feed usually works, second sheet can't make it to registration roller. Problem was not there before replacing Drum&Dev. I am in a hole on this one. Anybody got some ideas or experience. Much Appreciated
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Re: Bizhub 200 Abort errors and missfeeds after drum&dev replacement
    It is possible to have a short in the image unit that will do crazy things. I had one that was causing a false code for the fan. I would revisit the drum and look at contacts. Put another drum on it. Since it does not blow a fuse, it won't hut to try that.
    • xeroid
      • 148
      Problem Solved; Bad connection in Drum Unit. Thanks for the reply
      • Hansoon
        • Sep 2007
        • 3385
        Thanks for the feed back. Which connection? Bias?
        Hans
        • Hansoon
          • Sep 2007
          • 3385
          Hans
