c350 printer will only do one set at a time.
  • brent
    • Nov 2008
    • 1148
    I am doing a 4 pag e booklet double sided on landscape from a file. center fold and staple. no matter what I do. it will only do one set (booklet) at a time. any way around that? i know I met my quota with questions for today lol thanks
    brent
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: c350 printer will only do one set at a time.
    What program? I believe that Adobe acrobat pro has this limitation.
    • brent
      • Nov 2008
      • 1148
      I am going to try my other workstation. this is all because a customers machine will not print with windows 7 to a c350 I am double goofed for trying to do it myself.. lol
      brent
      • TheOwl
        • Nov 2008
        • 1733
        This sounds like the typical 'Collate' issue.
        Most applications that print have a Collate function which will send the document how ever many times you want copies to the machine. If you want 10 copies of a 4 page document, the application will send the machine 40 pages instead of just sending the whole job once and the machine then printing it 10 times.
        Leave the collate option on in the print driver, but make sure that you turn off the applications collate feature which is usually found in the print dialog box / screen.
        • brent
          • Nov 2008
          • 1148
          I will have to check out the collate. if that is it. I will be happy. even thought I was doing a job that we are done with it would be great to know if that was the issue.
          thanks to minolta. I may be able to sell another new machine. because windows 7 is not supported by the minolta c350.
          brent
          • pepper38_cnd
            Field Service Manager
            • Aug 2005
            • 1076
            Just use the Vista 64 Bit PCL driver and ignore all the Win7 warnings when installing. It will work Ok.
            Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
            Now into Ip TV KODI Boxes
            • brent
              • Nov 2008
              • 1148
              we tried a few different drivers. but the sort staple feature was not there. I just figured it would not work
              • Jazzwcs
                • Jun 2012
                • 40
                Could be a driver issue, app issue, firmware issue. Gonna need some more info such as firmware level, type of driver, and the application you are using.
                • brent
                  • Nov 2008
                  • 1148
                  I can get that information later. but I was told that windows 7 will not work with this machine. this is according to the kbms website
