bizhub 601 maintenance question
  • brent
    • Nov 2008
    • 1214
    I have the service book. question is. I am going to replace drum developer and blade today. do I use the book for adjustments. or the original set up instructions. the service book does not make it clear which way a person should go. because even on initial set up of a new bizhub 601 you do not do all the adjustments in the book. any thoughts? thanks guys. and gals
    brent
  • minimerlin
    • 851
    Re: bizhub 601 maintenance question
    brent
    I normally start with the last adjustment first..the developer mix, as my theory is that without a good tribocharge how can you be sure of proper black patches for the remainder of the set-up! I then do the drum blade setting...twice! Followed by the rest of the adjustments in the order in the book! I then run test print 12 as it gives a good grad test. Remember to clear the relevant counters before any set up is started.
    regards
    C
    Please do not PM me without asking first.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      minimerlin covered it well. Also if you are using an aftermarket drum, the grid voltage will be way off. A voltage will be on the end of the drum either embossed in the plastic or on a sticker. You must adjust the machine to match. Not hard at all.
      • brent
        • Nov 2008
        • 1214
        I am using oem everthing. I learned onthis model. (well the 5510) actually. it didn't pay to go non oem.
        I will refresh with the book.
        thanks
