Tonning problem on c500
  • starmech
    • Jul 2025
    Need help with a tonning problem this started after I fix a SC29-06 error code, it's a real light blue color
    think it might need m \developer I also change the charging corona !
    Thanks Ben
  • ni311
    • May 2008
    • 658
    Re: Tonning problem on c500
    Did you try to calibrate the machine? Did you run the internal adjustments?
    Konica Minolta Error Codes - Explanations and Solutions
