Minolta Bizhub 350 ADF (DF-605) problems
  • Kim Krell
    • Aug 2008
    • 43
    I have had several ADF (DF-605) go bad, When a copy is scanned it prints out way off center on the page. If I put a known working DF-605 on the machine it works fine. I tried the mech adj but it does not change the symtom, but If I put another top on it works fine. Help, I am running out of DF-605's.
  • Hansoon
    • Sep 2007
    • 3360
    Re: Minolta Bizhub 350 ADF (DF-605) problems
    I would say dusted up sensors.
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
    • mo0651
      • 1054
      Did you get a bad DF drive board?
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        I have never had one do that, but as per what hansoon said blow it out real good, and mo0651 suggested swap the board from a good one. When in doubt, change it out.
