C200 problem error
  • meyu334
    • Aug 2012
    • 20
    C200 problem error
    Hi. First sorry for bad english.
    I have Konica Minolta Bizhub C200 and i got Error C-6751 every power on. In Service Call Reports its look - 6751 CCD CLAMP GAIN ADJUST (16). I try to clean all optic, check the connection and i dont know where is problem. After got errror and open/close machine can only print. If i try to scan - error. Please help me fix that.
  • JustManuals
    • Jan 2006
    • 9838
    Re: C200 problem error
    Paul@justmanuals.com
    • meyu334
      • Aug 2012
      • 20
      SM dont help me fix that problem.
      • minimerlin
        • 851
        Is the scan lamp coming on? Have you cleaned the optics? Have you shut down mains power and rebooted? Is today a good day? Sorry but you ned to give a few details of what you have done to fix the problem. Are you a tech?
        Please do not PM me without asking first.
        • meyu334
          • Aug 2012
          • 20
          OK let me tell what i do.
          After Turn ON machine, it got error. I can skip this error and get staatus machine to Ready to skan ( just Open and close front door). Machine work as printer (close/exit door). If i try to scan - error. Also when we turn ON machine - Scane Fluorescent light is not lighting. Lamp is good ( tested on biz 250c). Engine of scan work. We try to clean optic, mirrors. Maybe upgrade firmware will give fix. Any question?
          • minimerlin
            • 851
            Does the scan lamp light up as you close the ADF down onto the glass? Has the lever at the back of the platten glass got stuck down? (the one that is pushed by the ADF). Sounds like you may have a problem with scan lamp power supply, or not done trouble reset correctly.
            • meyu334
              • Aug 2012
              • 20
              Thanks for the reply. When I turn on the machine with the open hatch and ADF lever depressed - lamp is not shining. I checked various combinations and light is dead. Yeaa, so we think the problem is in the potwer of scaner lamp. We will check it today.
              • meyu334
                • Aug 2012
                • 20
                Problem fixed!
                Thanks for help!
                • Hansoon
                  • Sep 2007
                  • 3374
                  .......and the solution was.......?
                  Hans
                  • meyu334
                    • Aug 2012
                    • 20
                    The problem was in the scan lamp power supply. We checked this by replacing part from the 2 machine C200.
