Bizhub C552 error code C-C180
  • scoonered
    • Oct 2009
    • 11
    [Error Code] Bizhub C552 error code C-C180
    Hi Guys
    I have today killed a perfectly good working machine by performing a firmware update. I have done this hundreds of times befor & it has never been an issue until today.
    Once the latest fimware was loaded I rebooted the machine & it comes to ready to copy state then after about 30 seconds or so it throws up error code C-C180
    I have reloaded the firmware several times & also tried older firmware but the same result every time.
    Any help appreciated.
  • emujo
    • Jun 2009
    • 3009
    Re: Bizhub C552 error code C-C180
    Found this for the C451, but it's probably applicable to the C552
    Also ensure you are using the C552, not the C552DS firmware
    Subject:
    CC180 error code.
    Description:
    CC180 error code.
    Solution:
    PROBABLE CAUSES:
    1. AU-201H card reader was installed without the driver. Prior to installing the card reader, the AU-201H driver/firmware must be downloaded to the MFP using the Compact Flash card.
    Download the AU-201H card reader firmware to the MFP. To verify the firmware is installed:
    a. Enter Service mode and select the Firmware tab.
    b. Select tab 4 and verify the firmware is listed under "Loadable Device Driver".
    Please refer to the attached firmware file and associated Release Notes.
    2. Corrupted or incorrect firmware caused a NVRAM failure.
    To correct:
    a. Re-flash the MFP with correct firmware.
    b. Perform a NVRAM Reset procedure then perform a NVRAM Initialization.
    c. Reboot the MFP.
    d. If you get a Security Pattern on the entire page (1/4-inch gray/black squares all over the copies) then perform the Copier Installation Procedure in the following order:
    • Touch Panel Adjustment in Accessibility settings
    • Gradation Adjustment in Service Mode
    • Date/Time setting in Service Mode
    • Date/Time setting in Administrator Mode
    • Enter Install Date in Service Mode
    • Serial Number Input in Service Mode
    • List Output in Service Mode
    If step "b" did not give you a MFP screen and you are still getting the C-C180, then replace the NVRAM. Step "d" is when you get a MFP screen and the error code went away, but you are now getting a box pattern. Emujo
