KONICA bizhub C-6000 code c-2813
  • d.v.ramanababu
    [Error Code] KONICA bizhub C-6000 code c-2813
    Does anyone have any thoughts on error code c-2813
    i inter changed Developing units even though the error code was same and i replaced new developing unit and charging units, drums also
    and also same problem and i done P.M procedure all parts. same problem. plz any body give good soluation.
    babu
  • JustManuals
    • Jan 2006
    • 9838
    Re: KONICA bizhub C-6000 code c-2813
    Paul@justmanuals.com
    • inutelkamo
      • Jul 2011
      • 143
      Gamma correction /M aborted. Patch output voltage is low. (Error 1)
      try to clean your color registration sensor...
      Or check your charging unit..
      • marlon29
        • May 2011
        • 51
        check the dust proof mirror of the write unit for any abnormal position
        • mariappanpm
          • May 2012
          • 14
          Have you swapped Charging unit (Cyan) with any other colour charging unit??
          • newmang
            • May 2011
            • 11
            Hi Did you resolve this? We also have this code on a C6000, intermittant but occuring more now. Also occasionally get C2814 Have replace Cyan dev unit / dev, Print control board, updated firmware, swapped transfer belt unit complete, swapped gamma sensor board. Works for a few hours then re-appears. Any ideas?
            • prakashshetty_thane
              • Jan 2011
              • 7
              First clean the IDC unit.
              If that doesn't solve the problem might just check all the charger units.
              Ii have faced the same issues and have found that the charger units were the culprit.
              • Amedeo
                • Sep 2011
                • 1
