Konica c6500 bypass tray wont go up, if anybody had that problem?
  • mariappanpm
    • May 2012
    • 14
    #16
    Re: Konica c6500 bypass tray wont go up, if anybody had that problem?
    Originally posted by jzheld
    tried to take a part bypass paper lift motor, all gears seems to be ok, but it's impossible to turn it by hand. I guess that is the problem.
    check 24V DC is coming to bypass lift motorif it comes change the motor,if not replace the convayance drive board
    • drodas78
      • Jun 2008
      • 91
      #17
      Hi, I'm having the exact same problem. How did you fix it? Please let me know.
      Thank you.
      • jzheld
        • Sep 2010
        • 162
        #18
        Thank you.
        Burned lift motor
        • drodas78
          • Jun 2008
          • 91
          #19
          Burned lift motor
          Do you have the motor part number?
          Thank you.
          • jzheld
            • Sep 2010
            • 162
            #20
            Thank you.
            sorry man I don't have it
            • gurko_gg
              Prod.Line Technician
              • Sep 2011
              • 43
              #21
              • lucky13
                • May 2008
                • 125
                #22
                you will never be able to turn that motor by hand (the way that it is geared) if you can turn it by hand it is broken
                • drodas78
                  • Jun 2008
                  • 91
                  #23
                  Hi, I've changed lift motor but problem remains. I want to try your solutions but is not so clear to me what do I need to do. Could you upload some images with reference to your solution suggest procedure?
                  Regards.
                  • drodas78
                    • Jun 2008
                    • 91
                    #24
                    Could you tell me how to check this? It has to be in I/O mode? The 24V DC are coming to the motor all the time or only when you tell the bypass to move up?
                    I think is worth mention that I've checked in I/O mode and the bypass don't move up but if I manually move it up then it moves down in I/O mode.
                    Thank you.
