Konica Bizhub 500 service mode problem
  • peter@digitalswebsite.com
    • Aug 2012
    • 29
    Hey everyone
    I have a Konica Minolta Bizhub 500 that says replace fuser, rebuilt the fuser, now it will not let me reset the counter, I go into trouble reset mode, then service mode , it lets me into service mode, hovever, when I select system 1 to go in and reset the counter, it just sits there, no matter what selection I make, it will not do anything, any ideas. I have never seen one do this
    Thanks in advance
  • blaze2000
    • Sep 2010
    • 232
    Re: Konica Bizhub 500 service mode problem
    Can you go into service mode directly? By that I mean NOT going through trouble reset mode.
      • Aug 2012
      • 29
      No, it will not let me
      • Shadow
        PHD in Sh!t Disturbing
        • Sep 2011
        • 455
        power off the machine and reboot while holding down the utility/counter key.
        then enter the service mode, enter the default access code and go from there.
        if all else fails, beat it with a big stick.
        $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
        • blaze2000
          • Sep 2010
          • 232
          Then something else is wrong... Pull the fuser a double check all your connections (lamps, thermistors etc)... Then try the trouble reset again.
