Toner for Bizhub pro C6500
  • copyguy1642
    • 22
    I have been told that the TK-612 toners can be used in the C6500. Is this true and if so do I need to make any modes to the cartridge?
  • eifling
    • Apr 2011
    • 43
    Re: Toner for Bizhub pro C6500
    Did you mean TN-612? If so why would you want to? They cost more than TN610.
    • copyguy1642
      • 22
      Sorry, I'm stuck in the Kyocera mode with TK... Yes I meant TN-612. I happed to have some TN-612 but I don't have any 6501 in the field, just some 6500
      • eifling
        • Apr 2011
        • 43
        If you look up close to the neck of the bottle, there are 2 tabs on 6500 and 3 tabs on 6501. Take the bottle and jam it in the machine with just a little force. Then pull the bottle out, look at the tabs, the ones that look a little dented need to be cut off. Cut it off and then your good to go.
        • mrwho
          Major Asshole!
          • 4299
          Easier to just compare both bottles and cut out the extra tabs on the new bottle. It's less likely you'll break anything inside the machine.
          Mascan42
          Ibid
          • eifling
            • Apr 2011
            • 43
            If you compare 6500 to 6501 toner, there is a tab that looks the same but its hard to tell that it is actually moved a slight bit. Also I didn't mean slam it in with the wrath of THOR
            • BVulgaris
              • Mar 2012
              • 32
              Got a question.....
              I've always been told that the OCE 6501 uses the 3 tabs, but the IKON's 6501 does not.... I've always thought this was strange but now im starting to think its B.S. and the Ikon 6501 i was shown might just be a 6500... any thoughts on this?
              • chriseckeard
                • Jan 2013
                • 7
                TN-612 has three tabs and the TN-610 has two. The TN-612 will run in the bizhup PRO C6500 but you need to cut of the middle tab of the three.
                I just ran a full CMYK set of the TN-612 in my C6500. Supposedly the C6501 has a higher yield per toner then the C6500 so I wanted to determine if it would also work on the C6500.
                On the same job I was able to get ~40K out of the black with the TN-610 but only ~35K with the TN-612. The color production is equivalent using the TN-612 over the TN-610 though I think the
                TN-612 was 5-10% lighter which could probably be improved with an adjustment.
                I needed to increase my yield by 22% to make it worth spending the extra money on the TN-612 over the Tn-610. My results proved that it was better to stick with the less expensive TN-610 Toner.
                FYI- I do run the DU-104 Drums which are intended for the C6501 in my C6500. They have a replacement interval of 300K rather then the 200K of the DU-102 drums and ~ the same in price.
