code 2152 c 360
  • mbhana
    • May 2025
    [Error Code] code 2152 c 360
    tried a new pwb board . but erroe code comes back after a day.
    pls can some one help.
  • Darren King
    copiertech
    • 652
    Re: code 2152 c 360
    Products:
    bizhub C360
    bizhub C280
    bizhub C220
    Options:
    None Specified
    Details
    Subject:
    Various error codes, such as C2152, C2253, C3201 and C5102 may be indicated as the MFP begins to run through stabilization. All the errors are drive motor related.
    Description:
    Various error codes shortly after power up.
    Solution:
    CAUSE: The MFP power supply is failing.
    SOLUTION: Replace the power supply (p/n A0ED M400 03).
    • mbhana
      Re: code 2152 c 360
      Originally posted by Darren King
      Products:
      bizhub C360
      bizhub C280
      bizhub C220
      Options:
      None Specified
      Details
      Subject:
      Description:
      Solution:
      thanks i will try it and see what happens and let u guys know if that helps.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Re: code 2152 c 360
        Does this code have the same meaning as per the old machines, ie, transfer belt internal colour transfer rollers retraction malfunction? (dont have my manual on me at the moment)
        If so, the transfer belt itself would of been the first logical step
        • JustManuals
          • Jan 2006
          • 9838
          Re: code 2152 c 360
          Paul@justmanuals.com
          • styaner
            Re: code 2152 c 360
            C2152
            transfer belt pressure welding alienation
            part # A0EDM40003 for power supply
            Have not seen this yet but we will as the machines age
            • habik
              • 2013
              Re: code 2152 c 360
              That is exactly where I would have started with ITB, check manually if it is easy to engage or disengage the 3 color 1st transfer rollers. Maybe one of them is hanging. Never had it so just guessing
              Firmwares HERE
