C6500 Jam on PFU5
  • dagoof
    Still learning...
    • 220
    [Jamming] C6500 Jam on PFU5
    Having problems with a 6500 - heavier stock is jamming in PFU5 horizontal conveyance (often double sheet). It will usually pick up first 3 sheets, jam - clear it, another 3 sheets and jam. The same stock runs out of PFU4 fine.
    I replaced the paper feed and separating roller on PFU5 - I didn't have a pickup roller so swapped over the one from PFU4 but still get the jam every 3rd sheet. Any ideas?
  • ni311
    • May 2008
    • 658
    Re: C6500 Jam on PFU5
    From Service Mode, activate the function to show you the jam code (J-xxxx), check in the service manual what sensor gives you this code and check the rollers just before this sensor.
    Konica Minolta Error Codes - Explanations and Solutions
    • seniortech
      • Dec 2007
      • 180
      Check the working position of the feed roller, very simple to do by removing the metal plate covering the sensors to the left of the pick up roller and then adjusting the height of the feed roller via the solenoid and sensor, adjustment is in the PF601 manual.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Gort
          Copier Demon
          • Oct 2011
          • 50
          1. Try to decrease or increase the tension on the DFP roller.
          With the tray open look at the left side of the drawer, below the DFP roller. There is a bracket that the assembly mounts to the drawer. The "knob" has 5 positions from weak to strong pressure for the DFP pressure. The center hole is the default. As I recall there is also an air assist adjustment for the trays.
          2. The solenoid on the feed assembly may be out of adjustment, there was something in one of the Troubleshooting guides on the solenoid adjustment.
          Sorry, I do not have a cat in my avatar.
          • dagoof
            Still learning...
            • 220
            Thanks all - will try as suggested on Monday (not DFP tension, had tried that).
