Hello,
I recently went to a machine with a c-5102 code ( main motor) I came back with the motor and replaced it. I ran a copy and got a jam, opened and closed the door then the machine cycled for awhile then ran a copy which came out blank and the control panel locked up. I checked the level history 2 in the service mode and the atvc level was at 0 when the machine came to ready. I thought maybe pinching a wire, looks ok, I came back with a pwb-m board, mfp board and a HVT board none worked. The only other thing it could possibly be is the ribbon cable that goes from the pwb-m board to the DIMM 0 board. thanks
