Konica 7155 Intermittent backgrounding... (Example Provided)
  • Doug James
    • Jan 2012
    • 935
    This happens every so often during long print jobs, the customer says that when they let the machine sit foor a bit, it will go away... Have changed the cleaning blade within the past few months... Pretty sure it is installed correctly...Sample Paper.pdfSample Paper.pdf
  • Luther
    • May 2006
    • 682
    Re: Konica 7155 Intermittent backgrounding... (Example Provided)
    Charge corona and grid need to be replaced
    • RRodgers
      • Jun 2009
      • 1947
      Be sure the ptl is clean as well.
      • Doug James
        • Jan 2012
        • 935
        Thanks so much... You guys are great !!!
