C5501 Touch Screen calibration out of whack
  • mrwho
    Major Asshole!
    • 4299
    [Electrical] C5501 Touch Screen calibration out of whack
    I've got a 5501 that, several times during the day, will completely lose the touchscreen calibration adjustment. The customer then tries to calibrate it, most of the times successfuly and it will last for a while until it loses it all once again. Sometimes the customer will not be able to perform the adjustment and he'll need to power cycle the machine, and when he does the touchscreen is back on alignment without the need to be calibrated.
    I'm assuming the touchpanel itself is not at fault, since it can be correctly calibrated and works fine for a while, without any dead spots. Seems like a memory thing, but what can I do? Adjustments? Replacement? The machine works fine beyhond this, so I'm open to suggestions.
    Thanks!
    Mascan42
    Ibid
  • Hansoon
    • Sep 2007
    • 3374
    Re: C5501 Touch Screen calibration out of whack
    Needs a new touch panel for sure.
    Hans
    • mrwho
      Major Asshole!
      • 4299
      Counter-intuitive (for the reasons I mentioned on the first post) but replacing the whole operation assembly did the trick so far.
      Thanks!
      Mascan42
      Ibid
      • JustManuals
        • Jan 2006
        • 9838
        If you need the manual for this beast, email me.
        Paul
        • mrwho
          Major Asshole!
          • 4299
          Paul
          No need, but thanks for the thought.
          Best regards!
          Mascan42
          Ibid
