bizhub c250 please see this....
  • goldencup
    • Nov 2008
    • 366
    Hi, i have bizhub C250 which is working good then suddenly the paper jams. I saw this very long rubber type of "whatever" about 27 inches long where is this rubber should be? Thank you.
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: bizhub c250 please see this....
    that's the belt tracking rubber, there's one at each inner edge.
    you need to change the transfer belt before it fails catastrophically.
    • goldencup
      • Nov 2008
      • 366
      Thank you for the reply sir, is this also the cause of P-21? I will replace the transfer belt, but of now i have no available belt yet, can i still use the machine or can i put back that rubber on the belt? Thank you very much
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        The belt wont be tracking straight with just one tracking rubber. Any number of P codes will theoretically be possible.
        It is impossible to put that rubber back on once it comes off. unless you have many hours of spare time to do it by hand
