Line on side edge
  • paulrid
    • Nov 2011
    • 206
    Line on side edge
    Hi all,
    Ive searched for this but can't see any info.
    I have seen a few c252/352 with a line on the side edge towards he back of the machine, line can be any colour. Most of the time it seems to me to be either paper position or IU.
    do ou guys have any thoughts on this?
    Thanks Paul.
  • minimerlin
    • 851
    Re: Line on side edge
    Happens quite a lot! Either change the IU that is causing the line..or just adjust the physical position of the paper trays to move the paper towards the front of the machine enough to be out of the area of the line! Make sure all trays are clear!
    Please do not PM me without asking first.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2142
      a temporary fix is to remove and reinsert the relevant IU after cleaning its HV contacts.
      I've had it come back 30 minutes later, a day later or not at all.
      You're actually better off changing it as it will constantly waste toner from the relevant IU.
      Stray toner in these machines is a problem enough in itself destroying imaging units by contaminating their charge grids, you don't need to add to the problem.
      • paulrid
        • Nov 2011
        • 206
        Thanks for he replays.
        What I should do when I have some time is take a faulty IU apart and check / clean he charge can and see if I can fix it, I'll let you know how I get on.
        Paul.
        • JustManuals
          • Jan 2006
          • 9919
          Paul@justmanuals.com
