Display shows 88
  • josephmeza
    • Oct 2012
    • 12
    Display shows 88
    I have a minolta DI 152 that show 88 on the display, there is nothing about 88 on the service manual, the display works fine, if you open covers the indicators will show on the display.
    If you turn it off or on it it powers everything comes on, but the DI 152 is locked up with 88 on the display.
    I had a suggestion of a possible Master board problem. Has anybody seen this problem........... Thanks for your help.
  • Hansoon
    • Sep 2007
    • 3389
    Re: Display shows 88
    Never seen this before. Any keys stuck on the operation panel?
    Hans
    • ni311
      • May 2008
      • 658
      Maybe you need a password and the control panel is locked?
      Konica Minolta Error Codes - Explanations and Solutions
      • josephmeza
        • Oct 2012
        • 12
        Hans
        No keys stuck, if you open panels the indicators on the control panel work, if you try to enter technicians, utility or administrators mode it does not respond it is locked with the
        88 on the display, if you open covers the di 152 will cycle normally but wont get past the 88 on the dispaly
        • ni311
          • May 2008
          • 658
          Can you upload a picture?
