Bizhub C35 - Jamming from tray 2 only
  • konikilla
    • Nov 2008
    • 43
    Hi Guys,
    I have loads of these little machines and have the same problem on 5 of them. It jams from tray 2 and doesn't usually get out of
    the tray when it jams. Only jams every 40-50 pages. I replaced all the seperation parts the feed roll, and feed roll clutch. I've also
    tried a lighter spring and a heavier spring.
    When it does jam and I open the tray and turn the roller gently by hand it does move the paper despite the fact it's touching the paper.
    It's like the roller isn't grippy enough.
    Anyone else having this issue? I can't find any bulletins on it.
    Konikilla
  • mmru4real
    • Aug 2008
    • 67
    Re: Bizhub C35 - Jamming from tray 2 only
    Originally posted by konikilla
    Hi Guys,
    Konikilla
    Put a shim between the 2 trays we have done this to everyone of our machines for the same issue and it resolved the problem on 12 machines.
    • konikilla
      • Nov 2008
      • 43
      Hi 4real,
      Sorry - Shim between 2 trays???
      It only has one tray. strangely called tray 2, tray 1 is the bypass on the side.
      Are you thinking of a different machine?
      Koni
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        make sure the metal plate under the separator isn't loose and sticking out catching the paper.
        • minimerlin
          • 851
          Also make sure all the little stick on pad / feet are still underneath the machine, they come off very easily and the tray gets twisted.
          Please do not PM me without asking first.
          • Mita-Konica-Tech
            • Jul 2011
            • 76
            It seems every time I work on one of these toys, I always get a call back...after installing new feed rollers....for jamming.... ??? were are you putting these shims ??? mmru4real ????
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              smaller the machine, the bigger the pain in the ass.
              • Windpomp
                • Nov 2008
                • 9
                Got the same problem. What is working for us is to carefully loosen the small metall plate under the feedroller and move it a bit up, maybe by 1mm at a time and test it.
                I am experiencing a new problem with these machines- error code 0094 ,"2nd image transfer/retraction failure". Any suggestions on this problem?
                • HoonBoy
                  • May 2011
                  • 130
                  Originally posted by Windpomp
                  Got the same problem. What is working for us is to carefully loosen the small metall plate under the feedroller and move it a bit up, maybe by 1mm at a time and test it.I am experiencing a new problem with these machines- error code 0094 ,"2nd image transfer/retraction failure". Any suggestions on this problem?
                  error 0094 is probably the torsion coil spring or the cover/guide that don't move smoothly ("Actuator" under the transferbelt )... Check TABT1200333
                  • konikilla
                    • Nov 2008
                    • 43
                    Thanks for the suggestions.
                    I've had the loose metal plate on several machines. Fixed it with selotape.
                    I'll have a look at those feet and try adjusting the metal plate and let you know.
                    Sorry never had a 0094.
                    Koni
                    • MAD0RAM
                      • Oct 2012
                      • 81
                      Also check the tray exit sensor in the vertical transport.
                      I found the flag for this sensor off the keepers causing jams once in awhile.
                      • avecosat
                        • Jun 2012
                        • 305
                        • JustManuals
                          • Jan 2006
                          • 9838
                          Paul@justmanuals.com
                          • mmru4real
                            • Aug 2008
                            • 67
                            The shim should be on the left side near the front cornercorner between tray 2 and 3. I can post pictures next week, it has fixed every machine we have that has the additional tray
                            • juve
                              • Dec 2012
                              • 86
                              paper jam transfer on two printers,40p(new) and 4650,before i start to replace cl1,cl2 and cl3.do you have any suggestion?
