Konica Minolta 7272 - Doest Not Print From Computer
  • shahid ahmed
    [Misc] Konica Minolta 7272 - Doest Not Print From Computer
    Recently I have purchased Konica Minolta 7272 Machine, its fine. I have installed the driver IP511A however, it does not print when I desire. You are requested to please help me in this regard
    Shahid Ahmed
  • Darren King
    copiertech
    • 652
    Re: Konica Minolta 7272 - Doest Not Print From Computer
    Riiiiiiiiiight!
    You are requested to enter IP address into copier.
    • shahid ahmed
      Originally posted by Darren King
      Riiiiiiiiiight!
      IP address is already entered in the machine, however, I am trying to contact through Parrell Printer Cable is it possible?
      • Darren King
        copiertech
        • 652
        I can't help you there. I have only used network printing on these.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • minimerlin
            • 851
            The parallel connector does not allow printing, if I remember correctly it is for updates! I maybe wrong I am only human!
            Please do not PM me without asking first.
            • RRodgers
              • Jun 2009
              • 1947
              Did you get the $1500 print chip with your copier? I would "guess" probably not. No chip, no print.
              • pepper38_cnd
                Field Service Manager
                • Aug 2005
                • 1075
                The Ip-511A is a big bubble that hangs on the back of the copier. If you go to printer and settings on the machine control panel you should be able to print a test page if you can't then you probably do not have the optional IP-511A. The network port on the main body is only used for scanning.
                Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                Now into Ip TV KODI Boxes
                • Synaux
                  • Mar 2012
                  • 1224
                  Request Received.
                  Assuming you actually do have the IP-511A physically installed and you want to print via Ethernet you must set the port (ip address in printer settings) to LPR1.
                  Otherwise, parallel is garbage and I have not even tried to print to parallel for several years now.
                  I would guess that minimerlin is correct, but if he isn't you probably would have to fiddle with the parallel port settings in BIOS
