c220/280/360 drums
  • Max
    • Oct 2011
    • 561
    c220/280/360 drums
    Are the colour and black drums the same in c220/260/360 colour copiers? Can i interchange them? Physically they look the same and black seam to fit in to colour slot without any problem. I was thinking of ordering black drums and using them instead of colour just replacing the ID chips on them. Can it be done?
    Ta.
  • habik
    • 2013
    Re: c220/280/360 drums
    Ta.
    Yes.
    Firmwares HERE
    • Wolli1207
      Yes the Drums are the same, only the ID-Chip is for the black another
      • Mike Watson
        • Oct 2012
        • 13
        Hi
        I thought that the black drums have a different resistance value than the colours, the colour drums are ok to interchange though.
        I could be wrong but that is what I seem to remember.
        • Kidaver
          Ghoulscout
          • Apr 2011
          • 912
          Just got out of class for this machine. If you put a drum in a machine you basically "marry" that part to the machine. So you can't just go swapping drums and devs for testing purposes. You have to go thru a certain setting in Service Mode to turn off the new item mode and then you can only get 10 copies out of the machine before it then marries the drum or dev to the machine. So just swapping drums and devs for testing purposes is a bad idea.
          "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
          • ni311
            • May 2008
            • 658
            The release function you are talking about in the Service Mode is used only you want to test a NEW drum / developing assy. With this function, the unit will remain 'new', meaning that when installed on a different machine it will be detected as a new item. But you can do whatever you want with the old drums, you can swap them with no problem, just it won't be detected as a new unit, that's all.
