Insert covers in copy mode on C364 ?
  • jazzfan1980
    • Jul 2025
    [Misc] Insert covers in copy mode on C364 ?
    Hello,
    I had an opportunity to see a bizhub C364 in action, but could not get the full applications menu in copy mode. Some features were missing, like the "insert cover sheet" seen on the C454.
    Is it due to some parameters in the admin section or is this a limitation due to the firmware of the equipment ?
    Thanks in advance for your answer !
    Lionel
  • TheOwl
    • Nov 2008
    • 1732
    Re: Insert covers in copy mode on C364 ?
    Originally posted by jazzfan1980
    Hello,
    Lionel
    Lionel, the C364 Series machines are capable of using the Cover Sheet mode.
    1. Copy
    2. Application
    3. Scroll to the right until section F) where you will find Cover Sheet
    • B0265
      • Jan 2007
      • 718
      Check this setting: Admin - System - Custom Display - Custom Function Pattern
      • jazzfan1980
        I do not have access to a C364 right now but I will check this next time.
        Thank you very much for your answer !
        Lionel
