Hello,
Customer has a bizhub c550, I am working on setting them up for scanning. They use scan to email and scan to PC via SMB protocol.
When I try to setup scanning via SMB, the machine deletes the job and says server connection error in the job details. This only happens when I use the computers hostname (i.e. frontdesk-pc), if I use the computers IP address the scan goes through just fine. I have DNS setup with the correct primary and secondary addresses.
I would think this would obviously be a dns problem if the scans work with IP address rather then hostname, although the scan to email works just fine using a smtp server hostname (so the dns servers are working if it is converting the email server's hostname to an ip address right?)
I have played around with all the smb and dns settings and have not been able to get this to work, what am I doing wrong??
I do these network installs a lot on ricohs, xerox, toshibas, so I dont believe I am doing anything wrong, unless I am missing a setting or something that I am not seeing.
Some more information: Network is not on a domain, firewalls are not blocking scans, computers are DHCP and cannot be set to static IP's, all other functions are working (scan to email, printing, fax), smb works with IP address.
PLEASE HELP IF YOU CAN.
Also another thing that is throwing me off is when the customer receives scan to email, the from address shows up as the previous owners admin email address, even though I have updated the settings in the machines web interface. I've looked at every setting on the machine and in the interface and cannot figure out why this is showing up as the wrong email address.
Thanks!
-Josh
Thanks!
-Josh
