Help everyone,bizhub 211 with nc-501 optionunable to scan-to-emailgetting error "cannot connect to smtp server"and "ntp server error" the moment you enter scan tabhere's what i've noticed so far;* I can ping it but unable to connect to pagescope* I have to restart the machine before I can enter Pagescope webconnect, even when directly connecting to machine.* Scan to ftp is ok* workstations on local using same smtp address are ok*also checked other email name for the machine.
Bizhub 211 scan to email problem
Re: Bizhub 211 scan to email problem
do you have smtp authentication turned on?
are you using the smtp server's name or host ip address?
do you have an email address set for the machine and administrator?
it sounds like you have missed a step somewhere.
go back to the basics and start again and don't try to get ahead of your self.$hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load -
if it is an external server, your isp, the ip address can change without notice.
page scope data admin is used to communicate with the machine itself from a computer, not the other way around.
are you using Microsoft exchange server for your email?
if so I believe that there is a different setup that needs to be done for it to work$hit Happens - Deal with it and move on.....................................sigpic....................................Lock & LoadComment
Yup they are using MsES, what I noticed is that eventhough i get a continuous reply from the machine when pinging it I can't connect to its pagescope data admin(not that it has something to do with scan2email). I'm starting to doubt that there is something wrong with the machine. Likewise, the Ntp server error always appears in the scan tab.Comment
there is a process for setting up scan to email with Exchange server, unfortunately I don't have that process.
I'm sure that some one on here might have it if you ask nicely$hit Happens - Deal with it and move on.....................................sigpic....................................Lock & LoadComment
I have the process, seeing as I wrote the docco... lol
Email with Exchange 2010.pdfPlease don't ask me for firmware or service manuals as refusal often offends.Comment
