pro c6500 error code c3201
  • alastair
    [Error Code] pro c6500 error code c3201
    Having a problem with a Konica Minolta Pro 6500,on start up the code c3201 appears,now i have replaced the sensor P16 still the same,checked the motor ans it seems to operate properly any other ideas?
  • alastair
    Re: pro c6500 error code c3201
    sorry that should be error code c3102
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • CopyJunkie
        • Oct 2012
        • 28
        Most cases I've seen it has been one way gears in the transmission section of the fuser. I normally replace the one way gears (Part# A03U809311) as a set of 3 although in a pitch I've only replaced the one that drives the Fuser belt.
        NOTES ON HOW TO USE THE FAX MACHINE.
        1. Get into your DeLorean (or your TARDIS) and go back to 1990.
        2. Place papers in the machine - Face Down.
        3. DO NOT dial 9
        4.
        Rejoin the rest of modern civilization.
        • astuto-2008
          paper jam in bizhub c6500
          C6500 bizhub change in the 3 gears (Part# A03U809311 m22t) had a paper, remove the paper jam Fuser, but gives the message machine jammed paper, we review the sensors and as usual have any idea to solve it?
