Konica 7272 or Minolta DI 7210 (developer drop)
  • remati
    • 149
    Hello people
    The problem is in old Konica 7272 (about 5 million copies)
    -Developing drop over transfer/separation corona and transport section..
    -Changed developer drum ,drum unit ,devoping unit (3 times,because the developer damage the gears,all the time),changed coronas all coronas...
    any more ideias??..to help..?
    thanks in advance
  • Synaux
    • Mar 2012
    • 1224
    Re: Konica 7272 or Minolta DI 7210 (developer drop)
    Originally posted by remati
    Hello people
    thanks in advance
    Well, the developer does like to leak on these...I have one leaking onto the transport section, but it is so slow I just left the old turd be.
    • Shadow
      PHD in Sh!t Disturbing
      • Sep 2011
      • 455
      you need to remove the developer unit and replace all the seals.
      this will stop the leaking of developer till the next time.
      $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
      • Darren King
        copiertech
        • 652
        9 times out of ten the problem is the charge grid. If it has a trail of dev up towards the fuser, then it is the grid. Cleaning it will temporarily fix it.
        Hope this helps.
        Darren
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • kalindd
            • Jun 2008
            • 192
            Like Darren King says most of the time problem is in charging grid. For some reason it is too close to the drum. I advise you to remove the brush that is cleaning the grid.
            Good luck.
