K-M C6000 Toner Unit Problem
  • ticky
    • Nov 2012
    • 2
    Hi there...
    Hoping someone can help with me with the error message "Please Set Replenish Toner Unit Correctly".
    I've played around with the machine as much as I can, tried Googling and such, but have yet to come up with anything at all to attempt to try and fix this.
    Thanks in advance...
    ...Dan
  • ni311
    • May 2008
    • 658
    Re: K-M C6000 Toner Unit Problem
    Replenish toner unit is the unit that is secured with two screws and comes to the right and these are unscrewed. The presence of this unit is signaled by a sensor positioned under the top cover. Check that sensor for proper functionality in Service Mode.
    • ticky
      • Nov 2012
      • 2
      Thanks. I end up discovering this from someone else.
      • ni311
        • May 2008
        • 658
        you're welcome
