C454 set max copies made at 1 time
  • mikez
    • Oct 2012
    • 30
    [Misc] C454 set max copies made at 1 time
    Is there a way to limit the amount of copies that can be made at 1 time. Customer keyed in 7000 copies on accident. Now they want a limit of 50 at time.
  • MAD0RAM
    • Oct 2012
    • 81
    Re: C454 set max copies made at 1 time
    Perfect example of over compensating for one stupid action.
    And I dont think you can limit the copy amount.
    You could limit the amount total in authentication.
    • mikez
      • Oct 2012
      • 30
      I didn't think there was either but i thought I'd ask. Thanks
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        Tell the obviously intelligent customer. You can disable all the paper trays except the bypass that way everyone would be limited to the number of sheets the bypass holds. Or he/she could just explain to the operators that pressing any number followed by the "0" key three times then pressing start key is going to result in over 1000 copies. Or you can explain that "As a Tech, stupidity has no technical solution!"
        Now into Ip TV KODI Boxes
