Gentlemen, good morning
konica C6500
I have a problem a few weeks. tone in the middle (yellow) density of 85% in overall profile of the output command workstation, generates some yellowish stains me like a drained by the image.
ja sent as line 1, 2; dot 1 and 2 and the problem persists.
put images in Annex 2. I do not know if the picture to identify.
cylinders 35%
developer 65% (developer (powdered)
coronas 5%transfer belt 60%
adjustments performed:
1 - User setting total
2 - auto adjust gamma sensor (manager mode)
3 - toner density auto adjust, print quality, auto gamma adjustment,
4 - new cylinder - initial drum rotation
5 - exchange kit 200k and 100k
6 - use EFI expectometro 1000, already calibrated several times -
7 - moved to place the cylinders
8 - swapped paper because the fiber
9 - including standard recall new date and recalibration.
others, faithfully follow the directions of the transfer roller as technical manual (electronic contact side).
thank tips
konica C6500
cylinders 35%
thank tips
