bizhub 250 with a 0x00900000
  • brent
    • Nov 2008
    • 1214
    this is a new code to me. I am going to get on it later tomorrow in the field. any advice or heads up?
    0x00900000 abort. thanks for any advice.
    brent
  • JR2ALTA
    • Feb 2010
    • 2033
    Windows 7 print job stuck.
    Clear queue on computer, set port from LPR to RAW in driver
    • Mick01
      • Nov 2012
      • 362
      Re: bizhub 250 with a 0x00900000
      Abort code 0x00900000 is related to fax so i assume that an FK-503 is installed in this machine.
      As a trouble-shooting procedure, please try the following:
      1. Enter Utility/Counter -> Admin. Management -> Enter the Administrator Code -> Admin 1 -> TX Setting -> Quality/Mode -> Communication Mode -> Change from Fax(G3) to PC + E-Mail. Check if fault still re-occurs.
      2. Remove the FAXS board and check if fault still re-occurs.
      3. Remove the MEM board and check if fault still re-occurs
      Hope this helps
      • brent
        • Nov 2008
        • 1214
        ok great. I am going to check it out right now and I will report back. thanks
        brent
        • brent
          • Nov 2008
          • 1214
          well I get the dumb shit award today. can I say that?
          the connector going into the fax board was slightly unplugged
          tripping the code every time. machine is fixed. I am happy
          but sheepish that I didnt seeit
          thanks
          brent
          • Hansoon
            • Sep 2007
            • 3389
            Don't worry, happened to me once too. I had to drive 120km into the Black Forest however for that. One week before I had a failing Printhead with the same machine..........
            Hans
            • JR2ALTA
              • Feb 2010
              • 2033
              good to hear, sorry I jumped the gun.
              • brent
                • Nov 2008
                • 1214
                you did not jump the gun. you tried to help. I am grateful
                brent
                • Mick01
                  • Nov 2012
                  • 362
                  Great to hear you got the machine operational. Good job
                  Regards
                  Michael
