Konica Minolta c6500 only black issue
  • jemsovic
    • Jun 2008
    • 48
    Had all drums replaced and coronas even tried new dew unit and still have issue see ATT img. any body had similar issue. Thank
  • JustManuals
    • Jan 2006
    • 9838
    Re: Konica Minolta c6500 only black issue
    Paul@justmanuals.com
    • jemsovic
      • Jun 2008
      • 48
      Originally posted by alamsandhu
      Did u clean the PH? filter glass for Lasers ? check the image on transfer belt looks fine?
      By PH you mean? Not 100% sure. Glas clean if I jam it intentionally same image is on drum. Transfer belt is new as well. Thanks for your replay.
      • jemsovic
        • Jun 2008
        • 48
        [QUOTE=alamsandhu;325468]Did u clean the PH? filter glass for Lasers ? check the image on transfer belt looks fine?[/QUOTE
        I know now PH you mean laser. I have service contract but my service man did not manage to get it up yesterday and I am losing business. I dont think hi cleaned PH only glass and everithing around drums.
        do you think some thing stuck in side laser unit.
        • Mick01
          • Nov 2012
          • 362
          Hi,
          From the sample you provided it is definitely in the black channel. Likely cause is the charge corona. Try swapping the charge corona between black and another colour and see if the fault transfers. In the future it is a good idea if you are attaching samples to indicate the direction of feed. Whether the band is in the feed direction or the main scan direction.
          Hope this helps.
          • Toxic
            • 698
            Relatively often have this problem on devices which work in a dirty environment or if you are using paper that has a lot of paper dust.
            A possible reason could be the hair that is left after cleaning on the laser beam path, usually on the upper side of the developing unit and interferes with the path of the laser.
            Try remove the black developing unit cleaned with an antistatic cloth.
            • blaze2000
              • Sep 2010
              • 232
              Looks like the K main charge assembly may need replacement/ rebuild or maybe just cleaned.
              • jemsovic
                • Jun 2008
                • 48
                Thank all to replay. charge coronas are new and drum also. swapping was already tried as well new dev unit. the lines are in upper part of print standard a4 print. will try tomorow its Holiday today. Thanks
                • blaze2000
                  • Sep 2010
                  • 232
                  Then it sounds as though you have something on the laser unit.
                  • jemsovic
                    • Jun 2008
                    • 48
                    Slit glass clean may be some thing behind hard to see. will see with my service man. when fixed will reply for benefit of forum. thanks
                    • mrwho
                      Major Asshole!
                      • 4299
                      Maybe something on the black developing unit's doctor blade - try to rotate the developing unit in the opposite direction a few times before rotating it back in the correct direction to see if the problem changes or goes away.
                      Mascan42
                      Ibid
                      • jemsovic
                        • Jun 2008
                        • 48
                        hi thought of that also brought new one since this one had samo years on it. will have some more info tomorrow. I was not present all time with him so am not sure 100 if hi tried every thing. I know hi did not remove PH to see if some thing is in. hopefully tomorrow problem will be fixed
                        • jemsovic
                          • Jun 2008
                          • 48
                          Cleaned K laser today. Now its even worse see att. they think its laser and will order new one. Its waiting game.
                          • mrwho
                            Major Asshole!
                            • 4299
                            I might be talking out of my ass, but did you check if it is possible to temporarily swap the laser with another color? And, if it is possible, why not try it before spending the money?
                            Mascan42
                            Ibid
                            • jemsovic
                              • Jun 2008
                              • 48
                              It would be possible if it was any of colors but K unit is difrent.
