Bizhub C 203
  • ogaliandy
    • Apr 2012
    • 14
    Bizhub C 203
    Hi,
    any one with an idea what could be wrong with C 203 it showed me error C 2561, which is something to do with the eeprom, after resetting through trouble reset, then system error clear, the machine is now showing to replace all the toner cartridge's and all the imaging units, any one seen this
  • Avskrap
    Partner in crime
    • Jul 2011
    • 160
    Re: Bizhub C 203
    I've had similar errors. Replace the PRCB (if you're tight on cash, check the ICPs)
    • JustManuals
      • Jan 2006
      • 9838
      Re: Bizhub C 203
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • ogaliandy
        • Apr 2012
        • 14
        Re: Bizhub C 203
        Thank you i will try the ICPs first
        • JSC
          Gimp
          • Dec 2006
          • 618
          Re: Bizhub C 203
          Check that one of the pins that the image units push onto have not been bent and are shorting out.
          The gene pool could use a little chlorine.
