IP 921
+ More Options
Posts
  • Beachguy
    • Dec 2007
    • 26
    IP 921
    It looks like the machine we have has a bad IP 921 controller. I know these are embedded in the printer (Coloforce 8050), but can they be bought as a seperate unit? If so how much and does anybody have one?
  • random
    What are the symptoms? might just need a reload.
    • Beachguy
      • Dec 2007
      • 26
      The printer is supposed to be a Printer/Scanner/Copier but it it thinks that it is only a copier. Also it is not recognized on the network. i.e. you can't ping to it.
      • random
        It has 4 red status leds on the side of it near where you plug the network cable in. Do they light up?
        • Beachguy
          • Dec 2007
          • 26
          Yes two of the four light up. The top left and the bottom right.
          • Tampa_Tony
            Beachguy
            If you have problems fixing your Controller, I do have both internal and external controller for that unit in stock. Please call me if you need any help
            800-265-2579
