Konica Minolta C6500 Error Code c-3903
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    [Error Code] Konica Minolta C6500 Error Code c-3903
    I am having an issue with a C6500 with an error code of c-3903, or high temp abnormality. It will reset and start to warm up and faults out within 30 seconds. We have swapped out the fuser unit and the PRCB yesterday. The machine came up and ran. The customer called it back in this morning for the same code.
    Anyone have any suggestions?
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
  • JustManuals
    • Jan 2006
    • 9838
    Re: Konica Minolta C6500 Error Code c-3903
    Paul@justmanuals.com
    • laserman06
      • Dec 2007
      • 323
      I have the manuals. I have been working on these for years. Just need some thoughts on things to try. Thanks anyway
      Ps 46:10
      • ni311
        • May 2008
        • 658
        With a strong flashlight, check the connectors on the back of the machine, between fusing unit and main body; pieces of paper from jams might endup there causing imperfect contacts.
        Konica Minolta Error Codes - Explanations and Solutions
        • Arcadian
          • Feb 2010
          • 218
          Laserman That guy with the manual always post his manuals, I find it redundant for him to post where he does not give any information he should be banned from here.
          Just Buy the manual. what the heck is that! Give a resolved answer then post his manuals, not always trying to make a buck. Geeesus!
          Since you swap the fuser Im guessing the fuser is not inserted correctly, you could try a different paper setting see if that works.
          I have one I have to look at this Monday. So ill let you know what I find and a solution for it I hope.
          • Arcadian
            • Feb 2010
            • 218
            Found the problem, this helped me.
            1) utility key, stop, 0, 0, stop, 0, 1 (this will allow you to be in service mode)
            2) press system reset (3)
            3) press software dip switch setting (1)
            4) left arrow so it reads 03
            5) right arrow so it reads 01
            6) touch off
            7) touch return, close, exit, exit
            If you cannot get to the utility menu turn off power then hold down the utiltity counter button then turn on machine while holding the utiliity button til menu comes up then goto software option then change the above.
            Awesome.
