ADU Konica C6500 doesn't work
  • Mick01
    • Nov 2012
    • 362
    #16
    Re: ADU Konica C6500 doesn't work
    542 is the three pin connector that plugs into the sensor
    • truongson
      • May 2011
      • 67
      #17
      I Saw on conveyance drive board just see 524 with 6 pin and 556 with 3 pin I can't find 542 with 3 pin as you'r guiding .
      • Mick01
        • Nov 2012
        • 362
        #18
        Hi,
        I am referring to the connector for the sensor 556 is on the board, 542 is the connector that plugs into PS27.
        See attached screenshot of the circuit diagramC6501ps27.pdf
        • truongson
          • May 2011
          • 67
          #19
          Hi,
          You will have to check continuity of the wiring from the board to the connector of the sensor.
          542 pin 3 to 556 pin 1
          542 pin 2 to 556 pin 2
          542 pin 3 to 556 pin 3
          Before you do that though confirm you are getting 5v at 542 pin 3 on the conveyance drive board. Put the red lead on pin 3 and black lead to ground.
          If you are not getting 5v on that pin check the 5v input to the conveyance board 507 pin 5
          Again hope this helps
          There is 5V input to the conveyance board 507 pin 5, but there is not 5V at 542 pin 3.
          • Mick01
            • Nov 2012
            • 362
            #20
            OK,
            Check for 5v at 556 pin 1 on the conv drive board. If you have 5V there you have a wiring break between the board and the sensor. If you dont have 5V then you have a faulty board.
            Kind regards
            • truongson
              • May 2011
              • 67
              #21
              OK,
              Kind regards
              if don't have 5V at 556 pin 1 the reason came from Printer Controller Board or not ??? Printer Controller Board is control them or not ?
              • Mick01
                • Nov 2012
                • 362
                #22
                No 5v supplied directly from DC power supply. You have already checked input voltage from there (507 in 5).
                If there is no 5v on that pin it may be a blown icp on the Conv board. Check all icp's.
                Kind regards
